Starting Mystery
Old Sep 17, 2007 | 06:52 PM
hdnvn's Avatar
Default Starting Mystery
Here are the facts...
My 2003 Polaris Sportsman 500 starts with the pull starter everytime. Although it cranks and cranks it will not start when using the starter. I first replaced the battery, no good. I have now replaced the starter. Still no good. I tried starting the quad in the dark so I might see anything shorting while using the key start. Nothing. It's been this way for about four months, I still go riding but am forced to use the pull start. Anyone got any suggestions? Thanks.
Old Sep 17, 2007 | 07:49 PM
Ramoel's Avatar
It sounds to me like the ignition switch may be bad. It might be giving you power to the ignition when just turned on but drops power to the ignition when in the start position. That would certainly explain your problem.
Old Sep 17, 2007 | 08:08 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
on that same line, take out the plug and then turn over w/ the key to see if its firing the plug. if not then hes right in what he said.
Old Sep 18, 2007 | 05:28 AM
dosceola's Avatar
Did u check all wires could be bad ground or like they said. if u know anyone with similar rride try swaping key assemblys and see. could be bad connection inside tumbler
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
