'95 Xplorer dies in reverse
Old Oct 5, 2007 | 03:23 PM
alwazmt's Avatar
Default '95 Xplorer dies in reverse
I have a 1995 Xplorer that has started dying when I put it in reverse. By this, I mean it stalls completely as soon as I put it in. If I use the override switch, it will idle and run fine in reverse. Forward gears and neutral work fine.
It just started doing this about 6 months ago. Battery is fairly new and seems to have all the power I need to start. Can a bad battery cause this problem. I was under the impression that the spark plug is grounded out in reverse to limit power.
Any ideas what else could be my problem?
Old Oct 5, 2007 | 03:34 PM
94harley's Avatar
A dead battery can cause the damage to cause the issue you are having. By replacing the battery, it still may not work correctly as the damage is done already. Most of the time the reverse limiter box is bad. Simple replacement usually fixes it. On rare occasions there can be other problems. Check it out first.
Old Oct 5, 2007 | 06:52 PM
ftwflh's Avatar
Find the reverse limiter box and unplug te black wire and your problem will be solved but you will have to watch out in reverse because it will run as fast as you give it gas.
pgamboa
Dec 24, 2023 11:52 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Jason Richards
Sep 4, 2015 06:17 PM
