china made atv's
Old Oct 8, 2007 | 08:00 AM
drhbluegrass's Avatar
Default china made atv's
i have a sunl so far, it's been tough, i have put it thur hell now i need the values adjusted how hard is it done, it's a remake, 150 honda eng. reproduction
Old Oct 8, 2007 | 10:55 AM
billl2099's Avatar
Remove the cylinder head cover.
Turn the cooling fan clockwise until the mark of the timing drive sprocket on the camshaft is at the
top, dead center, and the "T" symbol (or other mark) of the magneto flywheel aligns to the crankcase
mark.
When adjusting, loosen the lock nuts, adjust the bolts with
a valve-adjusting wrench when turned clockwise the valve
clearance decreases. And when turned counterclockwise
the valve clearance increases. Put a feeler gauge with specific
sizes between the valve and rocket to check for correct
clearance.
Take out the feeler gauge, tighten the lock nuts, and then inspect the valve clearance again.
Valve Clearance 0.08 ~ 0.12mm
Inspection and adjustment should be done in
cool conditions (below 35oC).
The crankshaft should corotate, or the exhaust port may not be adjusted.
Johnny Mac
Aug 15, 2019 03:13 PM
mrtidy
Feb 3, 2016 05:00 PM
wrencher82
Sep 30, 2015 04:27 AM
dakotah
Sep 26, 2015 04:25 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
