Engine Won't Shut Off
Old Oct 8, 2007 | 06:59 PM
WingingEd's Avatar
Default Engine Won't Shut Off
I am stumped!
My '95 Magnum 425 just won't shut off, either with the key or the kill switch. It started out as an intermittent thing, but now it's constant. I have replaced the CDI, rev limiter, battery, and key switch. I have checked and cleaned all the grounds and connectors. The only way I can get the engine to stop is to choke it or pull the coil wire.
Any advice or ideas are greatly appreciated.
Old Oct 8, 2007 | 08:48 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you ohm test the 2 switches to see if there closing the circuit?
Old Oct 8, 2007 | 10:44 PM
WingingEd's Avatar
Yes, I replaced the key switch from a known working one, then did a bench test to verify it was operating properly. I also traced the kill switch and tested it for correct operation, and it is.
A bit of additional information: It has about half of the power and speed as it did before. This symptom used to only be present when I would have the problem with getting the engine to turn off, but now it is also constant. So what would cause a loss of power AND inoperable kill switch at the same time?
bzdok1234
30
Feb 23, 2016 01:55 PM
ghost civic
Jul 20, 2015 12:36 PM
clsharky
Jul 13, 2015 02:07 PM
honda71
Jul 8, 2015 02:13 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
