pipes glowing red
Old Oct 12, 2007 | 09:50 AM
nvmyvettes's Avatar
Default pipes glowing red
I have 2004 700 Sportsman. After riding a short while the exaust pipe is glowing red.I know if a car does this I would look at stopped up converter or lean mixture on fuel. Would the same apply to atv?
Old Oct 12, 2007 | 10:13 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yes it would apply the same. there was a post about this a short time ago and a few guys said that theres does it and have since new because of thin pipes but myself i think its running too lean. also make sure the radaitor isnt partly plugged and causing it to run hoter then its suppose too. just an idear.
Old Oct 12, 2007 | 11:51 AM
tstroker's Avatar
if it is only a short distance, up to 4", you have nothing to worry about. if you ride them at 4000-5500 rpm the engine makes heat and it has to go somwhere. i would be more concerned if the header didn't glo a little. jmo.......stroker
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
Bigtwin700
Sep 9, 2015 09:32 AM
