Renegade lights
Old Oct 16, 2007 | 03:03 PM
08Renegade500's Avatar
Default Renegade lights
I haven't seen a thread about it yet, but I was wondering if anyone has figured out a way to burn all 4 headlights simultaneously on the renegade. I'm not complaining about the stock set up, but more is always better!
Old Oct 16, 2007 | 10:42 PM
JetTurtle's Avatar
So easy!!! Place the button between the hi and low beam position. OOOOOOOH MYYYYY GOD you will be so glad. Bye
Old Oct 20, 2007 | 09:09 PM
Mikey394's Avatar
My switch would always move so I did this.
Dual Head Light Mod:
Do this at your own risk, I have no idea if this with be too much of a load for the electrical/charging system on the Renegade 800. Maybe one of the electronic experts out there can check if this mod is too much for the electrical/charging system on the Renegade 800.
Ok with that said, This mod will allow you to run low beams and high beams with the switch in the high position. In the low switch position only lows will light, just like stock.
The connector is under the gauge cover. Follow the wire down from the handlebar switch and it will lead you to the connector. Find the Green wire and the Red wire with a yellow stripe. Add a jumper between those two wires and that?s it! Have fun!
UPDATE: so far so good, watch out for low Batt warning when running slow for a long time.
:thumbs:
Old Oct 22, 2007 | 11:21 AM
Thanks Mikey - that's more of what I was lookin for.
panicmanic
Sep 28, 2015 12:59 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Alex G.
Sep 16, 2015 12:13 PM
1000gade
Sep 9, 2015 04:41 PM
Canamaniac!
Sep 4, 2015 06:44 PM
