Is there a mechanic in the house? or someone who might be able to help?
Old Dec 3, 1999 | 06:58 PM
PLEA$URE's Avatar
CAN SOMEONE HELP ME! I have a 1987 Polaris cyclone... it's a 2 stroke pull start and i just got it back from the shop last night. today i was riding and it wouldent make it up a small dune so i looked at the motor and the rubber wasent over the connection from the pipe to the muffler... so naturaly i fixed it and rode for about a half hour! then i stoped for a while and about 15 min. later when i went to start it up it wouldent start. i pulled for about 10 min. and it finally started. when i got home i shut it off for about 30 min. and then it started up fine! will someone tell me why it would do that?
Old Dec 3, 1999 | 08:40 PM
mudmachine's Avatar
ok...
FIRST off.... what rubber thing on the exhaust system? Rubber tends to burn when it comes in contact with the hot exhaust... Be more specific...
Old Dec 3, 1999 | 09:02 PM
PLEA$URE's Avatar
alright, im not sure what it's called but it's a seal, where your pipe on the side comes out and meets your exaust! but thats not really the problom; its that it wouldent start... maybe it was flooded or somthing?
Old Dec 3, 1999 | 10:58 PM
mudmachine's Avatar
What was it in the shop for?.. what repairs and adjustments were made.? Did it do this before you took it in to be worked on?. Is the fuel fresh? Try turning the fuel off about 30 seconds before you shut it off, and remember to turn it back on before you start it. Not just when you stop for the day, anytime you shut it down, If the problem quits happening, then you either have a leaking needle/seat assembly in the carburetor, or the float level is too high.(either set too high or the float has a hole in it)
Oh, its a two stroke, also change the sparkplug.
Old Dec 4, 1999 | 12:41 AM
PLEA$URE's Avatar
thank you very much... i really appreciate it!
2quiker
Mar 22, 2022 08:36 PM
Customer Service #1
May 15, 2020 08:46 AM
flyin-lowe
Dec 1, 2017 03:18 AM
jdunne01
Oct 4, 2015 10:29 AM
Sassinm1
Sep 30, 2015 04:23 AM
