2004 1/2 500 oil change
Old Oct 19, 2007 | 12:58 PM
lhoyer's Avatar
Default 2004 1/2 500 oil change
I purchased this used machine a few months ago and changed all the fluids last night. The question concerns the priming of the oil pump. I followed the instructions but didn't hear the "hiss" of pressure I was supposed to hear. Before doing this the sump was way over full. After I did the procedure a couple of more times, the oil level is reading full-where its supposed to be. Am I correct in assuming that the pump is primed?
Old Oct 19, 2007 | 01:16 PM
TLC's Avatar
TLC
I just never did Polaris fussy why of changing oil. All I do is drain oil out of oil tank,once it stops I run motor for a few seconds and a additional cup of oil pours out of the oil tank. I replace oil tank drain plug than remover oil filter, I pour oil in the new oil filter (half full) and spin it on,than I start it up and let it circulate. Done.
I have done this on my dads 97 SP500 (He does nothing) since new that was 7000 miles ago. I had my Sportsman for a year and have done 3 oil changes this way so far.
Old Oct 19, 2007 | 01:17 PM
duffus's Avatar
Make sure you have found the slit in the tube and placed the clamps properly. If so, it is probably primed if you followed the instructions--- i rarely heard a hiss when I had a 500 -- you could do it again just to check. Essentially, it is bleeding the air from the lines to the engine. If your engine is knocking, it is not getting oil-- so keep your ears open for this.
Old Oct 19, 2007 | 04:49 PM
sheepdogMSP8117's Avatar
See THIS thread.
Nosniborpapa
Sep 12, 2015 05:54 PM
bigbear350quad
Sep 11, 2015 12:40 PM
Jason Campbell
Sep 7, 2015 02:25 PM
Elkaholic
Sep 6, 2015 02:44 PM
quickwhips
Sep 2, 2015 06:53 AM
