adc
Old Oct 21, 2007 | 08:44 AM
wayout's Avatar
Default adc
can you turn on adc while on the fly,you know can you push the button to adc while you're moving.....................
Old Oct 21, 2007 | 11:21 AM
Rcher's Avatar
Default adc
On my 800, ADC is engaged when 4wd is engaged. Polaris allows "shift on the fly" 4wd engagement.
Old Oct 21, 2007 | 02:08 PM
sheepdogMSP8117's Avatar
Default adc
With my '07 800 Deluxe, ADC is activated automatically when the switch is in AWD. Polaris' can be switched back and forth between 2x4 and AWD on-the-fly, therefore same with ADC. However, with the new models which ADC can be turned on or off independent of AWD, I can't say for sure. I'd assume it to be the same.
Old Oct 21, 2007 | 07:43 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default adc
the new 08' is differnt as you have 3 choices. the other one being to put in awd w/out the adc on. and yes you can use it on the fly as it only works under 15 mph anyways while its engaged.
