need some advice
Old Oct 22, 2007 | 10:49 PM
Ibrokeit's Avatar
Default need some advice
i just bought a 07 750 brute and have found a few probs.... 4wd goes in and out, diff doesnt lock most of the time, engine brake is insane, and front end clinks and clanks. anyone have input?
Old Oct 22, 2007 | 11:42 PM
quadzilla420's Avatar
Take it back and get a Prarie
Old Oct 22, 2007 | 11:50 PM
Ibrokeit's Avatar
nah, another king!
Old Oct 24, 2007 | 09:55 AM
that's what I meant, The king. "A Prarie"! did you know that in 2003 the Kawasaki Prarie 650 4x4 was the 1st quad introduced to the ATV world w/ the 1st big bore v-twin?
Old Oct 24, 2007 | 08:45 PM
JustRandy's Avatar
Its under waranty isnt it? Not much of a fan of V's unless its a V8 and that's just because it would be way too long to make it straight. Multicylinder inline engines have the advantage of higher rpm due to less reciprocating weight. 1-lungers have more on the low end torque, but can't rev out so high. A v will try to marry the 2 advantages and give you a bit of both worlds, but all of neither. Everything being equal, the brute should be faster and the king pull more weight.
Old Oct 25, 2007 | 12:23 PM
My Prarie pulls more weight than I've ever seen. I out pulled moded Brutes and and moded Polaris's at the Moundsville fair last year. Not to mention the Suzuki King Quad. And get this. My Prarie was stock as it still is.
Old Oct 25, 2007 | 05:35 PM
JustRandy's Avatar
The reason I think you are out pulling Kings is that the King has factory restrictions on the ignition timing. There is an upgrade box for about $500, but you have to stand in line for about a yr to get one. Brutes won't have enough on the lowend, they're designed more for speed. I don't know about polaris. And then there are gearing differences too between all the quads. Tires are different too. I tow cars around the yard with my 220 bayou and it has 3 inch bigger tires than stock,,, so the gearing is not that low. With a 650 you should be able to pull mobile homes around, lol. Factory towing specs come from drunken monkeys throwing darts at randomly place numbers in a large room.
Old Oct 25, 2007 | 10:27 PM
I hear that
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
