Alpha Sport 90-no power??
Old Oct 23, 2007 | 07:10 PM
turbo67camaro's Avatar
Default Alpha Sport 90-no power??
My daughters 90 had great power when we bought it, now it will barely take off. Once it gets going it seems ok though. Any ideas on what to check?
Old Oct 23, 2007 | 08:35 PM
fixit's Avatar
How old is the quad and how much time has been put on the machine . If the quad has power to ride you may have your primary clutch rollers worn. If you took off the clutch cover and the belt was at the top of the sheave, then theres a problem. And while your at it check the compression.
Old Oct 24, 2007 | 08:59 AM
I'll check it out, thanks!
Old Oct 24, 2007 | 08:20 PM
I removed the cover and everything looks ok. I haven't done a compression test yet, I have to borrow a tester. Where is the best place to get a new belt and gasket for the cover? I might as well replace it while I have the cover off.
Old Oct 25, 2007 | 03:03 PM
fixit's Avatar
You can get a new belt from any dealer for E-ton,or Polaris 2002 pred. All the same engines. As for the cover gasket you can use silicone for that.
Zehno
Sport Quads
Jan 2, 2016 01:31 PM
SyTye
Sep 11, 2015 02:45 PM
HYS
Aug 18, 2015 12:28 PM
John Boy
Jul 13, 2015 11:16 AM
tweeder
Jul 5, 2015 01:57 PM
