Lakota dying
Old Oct 23, 2007 | 10:56 PM
pg2001's Avatar
Default Lakota dying
Hi folks, just joined and have been reading thru trying to solve my problem.
Have some ideas from reading...but would like to ask my question for hopefully a definitive answer.
2000 lakota.....has been running great till battery died the other day. Did the pull start and all was well riding for about an hour. Lakota died and she would start on pull again, but no power and would only idle rough. put her in the garage overnight. She pull started next day (with backfiring) and would run for 15min, then starting losing power and fell back to the no power and idling rough only.
Carb was cleaned 3 mo's ago and needle replaced due to fuel leakage.
pls help....
thanks in advance,
Chris
Old Oct 24, 2007 | 10:35 PM
pg2001's Avatar
anyone ?? Bueller ?? Bueller??
pls
Old Oct 25, 2007 | 04:44 PM
Hayashi's Avatar
After starting the engine by either pull start on the original dead battery or a new battery, measure the voltage at the battery terminal. You should have 13+ volts if your charging stystem is working correctly. As you increase the rpm, the voltage reading should increase as well up to 14+ volts near the WOT. Engine might be dying because of poor charging system. You should get a new battery no matter what.
Old Oct 25, 2007 | 08:06 PM
pg2001's Avatar
thanks Hyashi,
thought i was all alone in the "Lakota" world.
I did get a new battery today and all is running great.
thanks again for replying, felt like a rookie asking a stupid question when no one else would respond.
Myself and three boys who love to go on rides are grateful !!!!
Old Dec 28, 2007 | 02:45 AM
Baseballroxmasox's Avatar
Wow lakota topics have really died out lately. Sorry for the late reply... I used to have a lakota, and I loved that thing.
It sounds like your carb got some dirt in it... but then again.. could be the charging system. Or both, for that matter! Go ahead and clean out the jets mainly, but the whole carb. Then check your air filter, make sure its nice and tacky, but clean enough. Hopefully you have it fixed by now so you can get out and ride again, but if not, hope this helps!!!
Old Dec 28, 2007 | 05:53 AM
JustRandy's Avatar
Your charging system is bad. Do like Hyashi said. And from now on try not to run anything on a dead or weak battery - it will burn up the charging system. Alternators are NOT BATTERY CHARGERS!
ultangler
Nov 30, 2024 01:35 AM
Pehter
Oct 3, 2024 11:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
2many2ride
Sep 27, 2015 04:35 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
