Brute with itp xtr, Like a new bike
Old Oct 27, 2007 | 04:45 PM
chevytrkn1's Avatar
Default Brute with itp xtr, Like a new bike
Just got my XTR's on my 06 brute 750, Rode it for 1100 miles with stock tires. Its like a whole new,better,different bike than stock. Anyone who owns a brute needs to upgrade the tires ASAP. I was starting to consider trading on a new Grizz because i thought the BF handled like crap. not anymore
I stuck with the 25's i weighed the new tired versus old and the new ones are 10 pounds heavier apiece so i may have lost some speed and acceleration, But worth it in my opinion.
Old Oct 27, 2007 | 07:38 PM
blackknight's Avatar
now remove the sway bar .and give that a try i for one will never reinstall mine .
Old Oct 28, 2007 | 12:47 PM
chevytrkn1's Avatar
What air pressure is everyone running with the ITP's i started with 5 and then lowered to 4, I think i could still go down a bit more
Old Nov 1, 2007 | 04:52 PM
Stones's Avatar
I run 5 psi in my 26" xtrs, i might lower it down there somewhat rough at that pressure.
Old Nov 2, 2007 | 03:57 AM
lowriderbowtie's Avatar
5.5psi in my xtr's
anything less and I seem to run the beads off the rims in hard corners
Old Nov 2, 2007 | 11:22 AM
Tangier's Avatar
You stuck with 25 ---- probably good unless you rally needed the 1/2 inch more in gc. The new tires will likely give you a little more gc anyway.
just out of curiosity did you stick with the same width or, if not, what did you go to front and back?
Old Nov 2, 2007 | 03:06 PM
JAM750BF's Avatar
Just got my new 2008 750BF and had the XTR's on it from the start. I also ran this tire on my 800 Sportsman. This BF is awesome......
Old Nov 2, 2007 | 09:06 PM
chevytrkn1's Avatar
I stuck with the same width, they were a bit taller than the stock ones being listed the same size. A buddy is running the 26's on his BF 750 and they look alot bigger.
I do mostly summer riding and if i used it more in the snow i might have gone bigger
Customer Service #1
May 15, 2020 08:46 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
lancemll88
Sep 6, 2015 03:03 AM
ylomnstr
Sep 4, 2015 05:02 PM
