eliminating key switch on raptor?
Old Jan 7, 2001 | 12:42 PM
dsEATER's Avatar
I Have pro tapers on my raptor with the factory black plastic key holder on them. I THINK IT'S UGLY! I don't really want to cut holes in the radiator cover for the key. Can I eliminate it? Would it burn up anything being wired hot? I was thinking of putting the neutral, temp and reverse lights on the little cover on the gas tank...
Old Jan 7, 2001 | 04:43 PM
Screamin96's Avatar
Im not sure about a Raptor, cause it has a battery. I guess it would always be "on" if you hotwired it causeing the battery to die. I hotwired my banshee, but that doesnt have a battery. If you can, i would just relocate it...if you do a good job of cutting the plastic, it should look great. Just be careful.
Hey check out https://atvconnection.com/ the best site on the net for ATV information.
Old Jan 8, 2001 | 08:55 PM
mtecate4g's Avatar
I put a hidden toggle switch on my raptor to get rid of the key switch and put the idicator lights on the radiator hood. it looks sweet. i dont have any pics of it yet but it is easy to do. The switch i mounted under the first luver of the hood on the left side. i had to extend the wiring a little bit since it wasnt quite long enough. the part i mounted the switch to is the small flange under the hood. any questions feel free to ask.
http://www.geocities.com/mattatv22/raptorpage.html
01 blue 660r
Old Jan 9, 2001 | 09:29 AM
xtreme165's Avatar
I remounted my qauges and key elsewhere. The gauges are in the rad cover up top where its in shape of a triangle and I put my key over on the right where the plastic curves around by the handlebars. I think it turned out real good and looks alot better than stock, I am not sure about eliminating key I'm sure you can I just dont have any expierance with it.
Old Jan 9, 2001 | 01:12 PM
No2StrokeBs's Avatar
You could splice the wires together and it would not run the battery down unless you left the lights on, if there is no draw on the battery it wont drain it, oh yeah, u might have to disconnect the neutral, reverse, and low oil lights
Old Jan 9, 2001 | 03:12 PM
dsEATER's Avatar
will it hurt the coil if left wired hot?
sweaver
11
Aug 18, 2015 03:47 PM
HYS
Aug 18, 2015 12:28 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cornermike
Jul 8, 2015 11:44 PM
