E TON 50-90cc 2 stoke suspension
Old Nov 2, 2007 | 09:35 AM
Da90ls's Avatar
Default E TON 50-90cc 2 stoke suspension
Does anyone know were to get suspension for that size bike? Im looking for something to take it up 2-4" higher. I knw where to get the rear swing arm which takes it 4" farther out, front a arms which take them 1" forward and 2" out the axle which takes the rear 2" out, and spacers. But I want t know where to get struts/spring kit to make it sit higher.
Also what are gd tires to use on these?
Old Nov 2, 2007 | 11:50 AM
ATV Crazy's Avatar
oops
Old Nov 2, 2007 | 12:12 PM
oldyeller's Avatar
Due to the single A arm front suspension you can't raise the suspension by the length of the springs/shocks..If you do you will get the front tires leaning out at the top edge which will make the bike very tippy in the corners and twitchy feeling when going straight ahead...Your only alternative is to go with a taller tire.
Robinhood
Dec 26, 2015 10:28 AM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
Nekolai1
Aug 25, 2015 10:04 PM
Mssarabug
Aug 10, 2015 12:56 PM
