Any help would be appreciated
Old Nov 2, 2007 | 11:44 AM
hudie01's Avatar
Default Any help would be appreciated
My wife has a Tomahawk 110 (Chinese) 3 speed. We went mudding and she got it stuck. Once we pulled it out it just would not move. When we shift the gears it shows that they are switching because the reverse light and the neutral light will come on when you get to that gear but it wont go. It to me seems like it is in gear but something isn't engaging.
Now my ignorance on quads comes into play. I know they say it is a clutchless 3 speed because it doesn't have a hand clutch to switch gears but it would still need some sort of clutch i would assume because i need to switch gears manually, so could it be the clutch is shot? And if this is the problem is that something i could fix myself?
Old Nov 2, 2007 | 12:06 PM
ATV Crazy's Avatar
even though it says it is clutchless it still has a clutch and it is a fairly easy task
Old Nov 2, 2007 | 12:10 PM
hardlydangerous's Avatar
Yep there is a centrifugal clutch in there... easy to change
Old Nov 2, 2007 | 12:16 PM
hudie01's Avatar
So from your opinion, does it sound like the clutch is my problem or could it be something else. I know it is hard to say without seeing it i am just tring to get a starting point. thanks again
Old Nov 2, 2007 | 12:28 PM
Other then that?
are the sprockets/chain intact?
it could be a torn up primary gear that drive the trans off the clutch but the clutch was likely fried when it was stuck if it was revved and the tires not allowed to spin. Either way the clutch has to come off to check it!
SOLOLUCKY
Oct 24, 2016 03:36 AM
slowgsxr97
Sep 8, 2015 04:37 AM
frostphase
Aug 19, 2015 07:11 PM
BigT137
3) General Discussions..
Aug 19, 2015 12:09 AM
