96 400 sportsman cooling question
Old Nov 2, 2007 | 08:38 PM
Timmerman's Avatar
Default 96 400 sportsman cooling question
I was replacing the front headlight bulb and seen a hose that was not attached to anything so i followed it down and it attaches to the cooling fan motor. Should this be attached to something? Also could someone tell me what the two switches on each side of the headlight are they are marked h off L?
Old Nov 3, 2007 | 12:33 AM
Charlie's Avatar
The hose is just for venting the fan motor. The switches if they are mounted on the headlight plastic may be for a winch or for grip heaters and/or thumbwarmer.
Old Nov 3, 2007 | 09:17 AM
ftwflh's Avatar
The hose going to the fan is to oil the fan.Use a little 3in1 in it every now and then
Old Nov 3, 2007 | 10:00 AM
Timmerman's Avatar
Thanks for the info guys. Ya probably the hand warmers.
bzdok1234
30
Feb 23, 2016 01:55 PM
1966F100
Jul 12, 2015 03:08 AM
toonces
Jul 11, 2015 12:01 PM
200es
Jul 10, 2015 09:09 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
