Need Carb Help - Dinli Diamondback 90
Old Nov 2, 2007 | 11:00 PM
stilinsm's Avatar
Default Need Carb Help - Dinli Diamondback 90
Just picked up a neglected 04 Diamondback. After i cleaned the carb, I was screwing the throttlebody cap back on and the thing split in two. Must have been a poor casting as there's another crack on the other side.
The carb is stamped Walbro PZ WFZ. I can't seem to find any info or the availability of replacement parts.
Anyone know any thing about this carb?
Old Nov 3, 2007 | 12:24 AM
biggkidd's Avatar
Fix it with JB WELD. Use a hose clamp then cover it in cold weld. You can probobly leave the clamp on after its done for added strength.
Larry
Old Nov 3, 2007 | 03:03 AM
stilinsm's Avatar
It's not the screw-down type. It connects with a through screw into the carb itself. I'm not sure it's shape will hold a hose clamp.
Old Nov 3, 2007 | 09:45 AM
biggkidd's Avatar
ok sorry
Larry
<div class="FTQUOTE"><begin quote>Originally posted by: stilinsm
It's not the screw-down type. It connects with a through screw into the carb itself. I'm not sure it's shape will hold a hose clamp.</end quote></div>
Old Nov 3, 2007 | 10:43 AM
hardlydangerous's Avatar
you lost me...
you say you were "screwing the throttlebody cap back on"
then you say "It's not the screw-down type"
Personally i have never seen a Walbro PZ carb that did not have a screw on cap...
but for what it's worth just about any briggs and Straton dealer should be able to order the parts for you or go directly to walbro. Ebay is always an option to.
Old Nov 3, 2007 | 02:22 PM
stilinsm's Avatar
pictures are here:
Broken carb picture 1
Broken carb picture 2
Already tried a high strength metal epoxy. Not enough surface.
Searched Ebay - no help.
Old Nov 4, 2007 | 09:56 PM
Awwww
check with local small engine shops they may have some of them layin around.
For a cheap fix you could JB weld the broken peice back on then cut out a piece of sheet metal the same shape as the entire cap, drill the two holes (one for the throttle cable one for the screw) and jb weld it to the cap. Basically the sheet metal cap is just holding the broken cap together and inplace once the screw is tightened down
if you need me to explain it better i'll draw it out on paint for you tomorrow
Old Nov 4, 2007 | 11:20 PM
stilinsm's Avatar
Hardly-D,
Thanks for the response.
I checked with a master welder. TIG or Heliarc could possibly do the job, but risky without knowing the metal composition.
So, the whole piece is currently under a mass glob of JB weld. Heck, I might even add another coat. Nothing to loose.
I guess I'll know in another 16 hours [img]i/expressions/face-icon-small-smile.gif[/img]
On another note, yesterday, went to a Polaris dealer who sold Denlis back in the day. They still had a couple '05s on the lot. The salesman said I could get a good deal on one, then he quoted me a $1900 price. I laughed. and told him I'll stick with my $200 one.
Old Nov 6, 2007 | 06:53 PM
stilinsm's Avatar
JB Weld is a wonderful thing
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
