Do I need to rejet my carb?
Old Nov 3, 2007 | 06:44 PM
faith41898's Avatar
Default Do I need to rejet my carb?
I recently bought a supertrapp mudslinger exhaust and a power chip for my 2006 750 Brute Force. When I hit the throttle there is no hesitation but when I let off it backfires somewhat. Can someone please let me know if I need to rejet the carbs or make any adjustments for fuel on the carbs at all? Thanks for your help. Brian
Old Nov 3, 2007 | 08:10 PM
quadzilla420's Avatar
Yep! You sure do. You're not getting the power you deserve for the power chip and exhaust. If you take the quad to the shop, they'll re-jet it plus all the other stuff that needs to be replaced. If you've done everything you said, it sounds like your metering rods.
Old Nov 4, 2007 | 01:38 AM
vbalz's Avatar
get it rejeted as soon as possible bro, don't keep running it that way, you could burn a valve or cause other engine damage
Old Nov 5, 2007 | 01:03 AM
JustRandy's Avatar
Quote from http://www.supertrapp.com/resource/faqs.asp#20
Q. Why do some aftermarket pipes backfire when you decelerate?
Backfire, or "lean misfire" on deceleration is primarily attributed to an improperly tuned engine. Under this circumstance, the low speed fuel circuit needs to be adjusted. On a street bike, the rule of thumb is to adjust the fuel mixture screw out in ½ turn increments to add fuel. If you reach 3.5 turns out and it still pops on decel then go up one size on the pilot jet and turn the fuel mixture screw back to one turn out from bottomed. Repeat this process until the misfire is eliminated. In some cases, this problem is an indication that the exhaust is too free flowing (i.e. Head pipes too large in diameter or muffler core is too large) for the motor configuration you have. As always, check your spark plugs to verify the tune is correct. The plugs should be a light tan in color if tuned properly. If the exhaust is too "free flowing" you will ultimately add too much fuel which will cause an excessively rich condition and foul the plugs.
Old Nov 5, 2007 | 07:44 PM
faith41898's Avatar
Thanks so much for your reply. I will not run it again till I get it checked out
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
cSchwartz
Jul 9, 2015 02:43 PM
