slow raptor 50
Old Nov 8, 2007 | 06:38 PM
newbie24's Avatar
Default slow raptor 50
how can a guy make a 50 go faster with out spending a fortune i was told by a yamaha tech the only way to make a 50 go faster is to buy an 80. (ha ha ha)any have any ideas?
Old Nov 9, 2007 | 01:04 AM
EdKatt's Avatar
intake, exhaust, sprocket change
Old Nov 9, 2007 | 07:30 AM
atvingnc's Avatar
There are a bunch of changes you can do to the Raptor 50 to improve performance.
1 - change carburator slider to Raptor 80 version ($20).
2 - change throttle lever to Raptor 80 version ($10).
3 - change to higher rev CDI (around $100 but you might get one used or new
on ebay for less)
(changes 1, 2 and 3 will give the greatest speed and power increase)
4 - change main jetting to #80 (some power improvement, $10)
5 - add after market exhaust (adds a little horse power, but expensive,
there is a power tip on ebay ($30) that doesn't cost as much and may
help some)
6 - perform clutch ball removal modification. (helps with starting off, $10).
7 - add wheel spacers for stability. (highly recommend if 1,2, amd 3 are done)
8 - add offset rims and after market tires for better handling/stability ($400)
9 - add nerf bars for safety ($100)
10 - add headlight for night riding ($150)
pick your poison.
do a search for Raptor 50 under this sub-forum and look for
04-05 Yamaha Raptor 50 and a couple of other discusions for more detail
also go to
http://www.raptorforum.com/index.php?board=13.0 or
<a target=_blank class=ftalternatingbarlinklarge href="http://www.exriders.com/vbb/forumdisplay.php?s=&forumid=48
">http://www.exriders.com/vbb/fo...p?s=&forumid=48
</a>
some good discussions there also.
Old Nov 12, 2007 | 03:49 PM
Dragginbutt's Avatar
Is old enough to know better, but too young to stop.
raptor80racing has a lot of products available for these..... OBTW, For Edcat... sprocket change? On a shaft drive?
Old Nov 12, 2007 | 03:51 PM
The Raptor 50 is slow by design... The dealer wasn't far off in his response. Selling a 50 can be easier than you think. They keep their resale quite well actually, and if your son is ready for an upgrade and his size dictates a larger machine is needed, it should be considered.
Old Nov 13, 2007 | 09:48 AM
LT80's Avatar
LT80 Expert
I agree w/dragginbutt.
Please check out the DRR quads. Fast out of the box!
I feel you will sink a bunch-o-money on the raptor 50 and still not come close to what you want to achieve (a kid with a big smile).
Old Nov 13, 2007 | 10:30 AM
Scooter86's Avatar
Knows Old ATV Questions!
To many design limitations on the old 50. You could probably sell that one and buy a larger used one for less than $500.00 total investment. That is provided your little one is big/mature enough for more power and a larger chassis. BTW, I would probably stay away from the Raptor 80 too. There are plenty of stock quads out there that are going to keep your kid happier, longer.
bmxatv10
Oct 14, 2022 06:23 PM
ReconBayou
Sep 23, 2015 02:41 PM
black_thunder
Sep 22, 2015 07:59 PM
black_thunder
Sep 20, 2015 10:21 PM
black_thunder
Sep 6, 2015 04:41 PM
