2003 Prairie 650
Hayashi
highwaydan posted this message the other day and I told him that you'd be able to help him since he and I have the same year, make and model quad and every Q I've ever had about mine you always gave me the right answer or gave me the variables to decide on.
- I replaced the front cv boot on my 650 and when I did I serviced the CV joint and reinstalled and when I put the tires back on it and let if off the jack the CV joint pops out of the gear box about a 1/2 inch and will not stay engaged. I disassembled and reassembled 2 times putting new C clips on the end of CV shaft before installing. Has anyone else had this problem and if so, what can I do to fix this. I need some help with this. -
highwaydan,
I have not experienced your problem even though I've installed cv axle several times on front diff gear box of P650/700. You should hear a clicking sound or at least feel bottoming out when pushing in the inboard spline end of the cv axle into the gear box. Are both sides having this problem?
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
