2003 Prairie 650 4 x 4
Hayashi,
I replaced the front cv boot on my 650 and when I did I serviced the CV joint and reinstalled and when I put the tires back on it and let if off the jack the CV joint pops out of the gear box about a 1/2 inch and will not stay engaged. I disassembled and reassembled 2 times putting new C clips on the end of CV shaft before installing. Has anyone else had this problem and if so, what can I do to fix this. I need some help with this
Is the joint moving like it should (extending and collapsing) ? is it fully seating in the diff ? It should lock in place when pushed in far enough. Is the snap ring groove clean have dirt or remains of the clip in it? I'm just thinking out loud.
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
