07 predator 50 help
Old Nov 13, 2007 | 05:20 PM
Rhinopkc's Avatar
Default 07 predator 50 help
I have a 4-stroke predator 50, my daughter is too short for a 90, but her abilities have outgrown the 50. Is there any way to give this engine more pep? Does it have any restrictors in the exhaust/intake? Are there any performance cams or big bore kits available?
Old Nov 14, 2007 | 05:33 PM
AIRMOBILE101's Avatar
I don't think the four stokes have restrictors in the intake or exhaust. Im not 100% sure. Have you tried a no rev cdi box? Different rear or front sprocket? Bigger tires? That stuff will give it more top end. Is the bike actually made by Polaris or is it a Kymco or E-TON? Is it a cvt transmission(belt driven)? Have you checked to see if it has a spacer where the belt rides on(assuming its a cvt)? Remove it if it does. Hope that helps to a certain degree.
Old Nov 15, 2007 | 04:53 AM
Rhinopkc's Avatar
I don't know where to find a different CDI box, and I don't know if someone else makes it. It has pretty big tires on it, and I would like it to have more power all the way around, not just top speed. Thanks for the ideas, though, I'll check the cvt.
Old Nov 15, 2007 | 08:44 PM
biskit134's Avatar
Not wanting to bust your bubble, but I think that there are not alot of upgrades available for that unit. I would sell it, as they are going pretty well if they are in good shape, then I would buy a larger one. You would likely spend close to what it would cost to upgrade that one. Higher rpms will not give you all the way around power. I do not think a CDI box will give you any felt bottom end performance.
Old Nov 16, 2007 | 06:31 AM
Rhinopkc's Avatar
I'll probably just keep it for my little guy, and figure something else out for my daughter.
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Elkaholic
Sep 6, 2015 02:44 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
