Finely Tuned Raptor ****SWEET as SEX***
Old Jan 8, 2001 | 10:15 PM
raptorfast's Avatar
I have been playing around with my Raptor and trying to figure out what it need to be tuned with the complete BG Exhaust and this is what I have discovered. Carbs are 180/185with PJ's @ 27.5 and a Pro Design Airbox with 6 1" holes that give this thing a whole new dimension of power. The 12 Tooth spocket is a must for short track and trails. HAS ANYONE FOUND ANYTHING DIFFERENT AS FAR AS TUNING THE CARBS????
Old Jan 8, 2001 | 10:59 PM
bartolo's Avatar
Did you ever try it with the recommended 150/155? If so, why did you settle for the 180/185?
Thanks,
Bart
http://members.home.net/bartkim/
Old Jan 8, 2001 | 11:03 PM
raptorfast's Avatar
I tried the recommended 150 and 155 like BG says but it cut out at top end unless I pulled the choke ina bit. I did a ton of research and tried what the boys are using on the west coast used and it pepped right back up. I hope I am right. I wish there were an easier way to dial it in. What are you suing for jetting?/
Old Jan 9, 2001 | 12:05 AM
660rRider's Avatar
Is it possible that your mains are too rich? Are you staying close to the proper jetting requirement for your Raptor, with the proper procedures, or are you just going too far on the mains and not realizing you are too rich? When you hit the "sweet-spot", it will be awesome. Good luck!
Old Jan 9, 2001 | 12:14 AM
DesertRaptor's Avatar
Try this website....
http://www.factorypro.com/tech/carbtun.html
Old Jan 9, 2001 | 10:19 PM
raptorfast's Avatar
Follow steps in order....First, dial in:
1. Top end (full throttle / 7.5k to redline - Best Main Jet be selected before starting step 2!
Select Best Main Jet
To get the best, most even top end power (full throttle/after 7500 rpm), select the main jet that produces the highest top speed / pulls hardest at high rpm.
If the bike pulls harder at high rpm when cold and less hard when fully warmed up, the main jet is too large. Install a smaller main jet and retest until you find the main jet that pulls the hardest at high rpm when fully warmed up. This must be done first - before moving on to the other tuning ranges.
If the bike doesn't pull well at high rpm when cold and gets only slightly better when fully warmed up, the main jet is too small.
In order to properly tune the midrange and low rpm carburetion, THE MAIN JET MUST FIRST BE PROPERLY SELECTED after 10 to 15 minutes of hard use!
Do not pay too much attention to the lowend richness when you are changing main jets - you still need to be using the main jets that produce the best power at high rpm. You will deal with the lowend / cruise later - after step 2.
2. Midrange (full throttle /5k-7k)
Select best needle clip position
To get the best power at full throttle / 5k-7k rpm, after you have already selected the best main jet,
If the engine pulls better on a full throttle roll-on starting at <3k, when cool but soft when at full operating temperature, it is too rich in the midrange and the needle should be lowered.
If the engine pulls better when fully warmed up but still not great between 5k-7k, try raising the needle to richen 5k-7k.
If the engine pulls equally well between 5k-7k when cooler as compared to fully warmed up, the needle height is probably properly set.
Do not pay too much attention to the lowend richness when you are changing needle clip positions - you still need to be using the clip position that produces the best full throttle / 5k-7k power in conjunction with the main jets that produce the best power at high rpm. You will deal with the lowend / cruise next.
3. Low end (full throttle / 2k-3k)
Float height (AKA fuel level & how to..)
To get best lowend power, set float height so that the engine will accept full throttle in 2nd gear from 2.5k to 3k rpm at minimum.
Float heights, unless otherwise specified in the installation guide, are measured from the "gasket surface" of the carb body to the highest part of the top of the float - with the float tang touching but not compressing the float valve spring.
If the engine has a "wet" rhythmic, soggy area at full throttle / 3k-4k rpm, that gets worse as the engine heats up, lower the fuel level by resetting the float height 1mm greater (if the original was 13mm - go to 14mm). This will lower the fuel level, making full throttle / 2k-3k rpm leaner.
If the engine is "dry" and flat between 2k to 3k rpm, raise the fuel level.
Example: change float height from 15mm to 14mm to richen up that area.
REMEMBER, since the main jet WILL affect low speed operation, the MAIN JET has to be within 1 or 2 sizes of correct before final float setting.
Warning: If the engine is left with the fuel level too high,, the engine may foul plugs on the street and will be "soft" and boggy at part throttle operation. Adjust Floats to raise/ lower the Fuel Level.
Base settings are usually given if a particular application has a history of fuel level criticalness. The Fuel level height in the float bowl affects full throttle/low rpm and, also, richness or leanness at cruise/low rpm.
Reference: a bike that runs cleanly at small throttle openings when cold, but starts to show signs of richness as it heats up to full operating temperature, will usually be leaned out enough to be correct if the fuel level is LOWERED 1mm. Check out and RESET all: Suzuki (all), Yamaha (all) and Kawasaki (if low speed problems occur). Needless to say, FUEL LEVEL IS EXTREMELY IMPORTANT!!!
If there are lowend richness problems, even after lowering the fuel level much more than 1.5mm from our initial settings, also check for needle wear and needle jet (part of the emulsion tube). See Worn Needle and Worn Needle Jet diagram. It is VERY common for the brass needle jets (in the top of the "emulsion tube") in 36mm, 38mm and 40mm Mikuni CV carbs to wear out in as little as 5,000 miles. Check them for "oblong" wear - the needle jet orifice starts out round! Factory Pro produces stock replacement needle jets / emulsion tubes for 36mm and 38mm Mikuni carbs.
4. Idle and low rpm cruise
Fuel Screw setting (AKA mixture screws)
There is usually a machined brass or aluminum cap over the fuel screws on all but newer Honda. It's about the diameter of a pencil. Cap removal details. Newer Honda carbs use a special "D" shaped driver, usually supplied in the carb recal kit.
Set for smoothest idle and 2nd gear, 4k rpm, steady state cruise operation. Set mixture screws at recommended settings, as a starting point. For smoothest idle, 2nd gear 4000 rpm steady state cruise , and 1/8 throttle high rpm operation.
Pilot fuel mixture screw settings, float level AND pilot jet size are the primary sources of mixture delivery during 4000 rpm steady state cruise operation.
If lean surging is encountered, richen mixture screws (turn out) in 1/2 turn increments. Alternative pilot jets are supplied when normally required.
Pilot fuel mixture screw settings, float level and pilot jet size also affect high-rpm, 0 to 1/8 throttle maneuvers. Too lean, will cause surging problems when the engine is operated at high rpm at small throttle openings! Opening the mixture screws and/or increasing pilot jet size will usually cure the problem.
NOTE: A rich problem gets worse as the engine heats up.
If the throttle is lightly "blipped" at idle, and the rpm drops below the set idle speed, then rises up to the set idle speed, the low speed mixture screws are probably set too rich: try 1/2 turn in, to lean the idle mixture.
NOTE: A lean problem gets better as the engine heats up.
If the throttle is lightly "blipped" at idle, and the rpm "hangs up" before dropping to the set idle speed, and there are no intake leaks and the idle speed is set at less than 1000 rpm, the mixture screws are probably too lean: try 1/2 turn out, to richen mixture. Be sure there are no intake leaks and the idle speed is set at less than 1000 rpm!
Carb tuning is a combination of science, art, intuition and a lot of wizardry. These tuning kits have been thoroughly tested to ensure easy, trouble-free, optimized performance.
Please note: If you have installed the kit and gone through the optional screw settings, clip positions and main jets, and still have a persistent flat spot/problem, we ask you to call us. Unique engine/exhaust/filter/altitude/temperature combinations may require individualized setups. We are here to help. The information gained to your solution will be installed in our computerized reference database. PLEASE CALL!
We ask that upon completion of installation and tuning, that you call us with specifications of your installation, (pipe brand, filters, advancer, altitude, humidity, temperature and final carb settings) to be entered in our TUNING DATABASE. The database allows us to include the "most used" jet sizes and setup specifications in every kit. Use (415) 721-4964, (800) 869-0497 or fax (415) 454-8803. Thanks! Marc W. Salvisberg
Old Jan 9, 2001 | 11:05 PM
Ya, nice cut and paste BJ.
Old Jan 10, 2001 | 01:17 AM
raptorfast's Avatar
I tried the website desertraptor suggested and it worked great. I cut and pasted it for ease of viewing. Many thanks to the guy at the bottom of the page for his insight.
Great job desertraptor - I am sure many people wil benefit from your findings and my paste job.
Old Jan 10, 2001 | 10:45 AM
Ya, now this is how a forum is supposed work, ATV people helping each other.
Old Jan 10, 2001 | 12:52 PM
ERICsRAPTOR's Avatar
Scratch my back and I'll scratch yours...this is what I like to see.
