lt80 clutch slipping
Old Nov 24, 2007 | 05:41 PM
Humanator's Avatar
Default lt80 clutch slipping
My daughters lt80 seems like the clutch slips under load but it's not a normal slip. It acts like the chain is jumping teeth but the chain and sprockets are new. Any suggestions? I checked the belt and it looks fine, no shavings.
Old Nov 25, 2007 | 10:33 AM
LT80's Avatar
LT80 Expert
But is the chain tight? If so, block the rear end up and spin the tires. Feel and listen for grinding in the gearbox (by front sprocket). Usually no gear problems but it can happen.
Providing all is well there, I'd service the clutchs to see if there is something wrong in there.
I'm still betting on the chain jumping.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 25, 2007 | 01:02 PM
Humanator's Avatar
I installed a chain tensioner so the chain is tight. I will check the gear box for noise. Also... it's been hard to start lately, the carb is clean so I think it might be reeds.
Old Nov 27, 2007 | 09:51 AM
LT80's Avatar
LT80 Expert
Check the compression. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 27, 2007 | 10:00 PM
Humanator's Avatar
The compression is 115lbs and there is no grinding in the gearbox when I spin the wheels.
Old Nov 28, 2007 | 10:56 AM
LT80's Avatar
LT80 Expert
Ok, the reed may be cracked but it sounds like you'll need to service the clutchs to check all in there. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 28, 2007 | 03:48 PM
Humanator's Avatar
Thanks... when I have it apart... what mods do I do.
Old Nov 28, 2007 | 05:40 PM
LT80's Avatar
LT80 Expert
Leave 2 rollers out for a stock motor with a stock pipe. [img]i/expressions/face-icon-small-smile.gif[/img]
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
jbrewster94
Sep 23, 2015 04:16 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
