polaris gurus help 2000 scrambler 2x4 rebuild
Old Nov 25, 2007 | 10:40 PM
gscrambler's Avatar
Default polaris gurus help 2000 scrambler 2x4 rebuild
just rebult my scrambler ,new piston ,rings and wrist pin.Changed fluids flushed everything. Iput it back together,cant get anyone to tell me how much oil and what kind to use in the counterbalance.Anyways tried a half quart as told by a fellow owner(he was unsure).I started it up and ran ,idled great for about 2 min,fouled a plug??? No biggey. Put in a new plug, started it,30 seconds later started smoking bad and would'nt stay running.It would startup haveing to give it almost full throttle, it would start to die ,hit the gas and it pepped back up, then foul the plug again. I did this for 3 hours ,same results. drained the oil ,opened all the drain plugs ,the inital oil i had put in all came out and also about a teaspoon came out of the plug beside it, (the air box ?on an angle under the starter motor???)it was black oil. The smoke smelled like motor oil ,2 cycle smells different.DAmn thing sounds strong no raping or pinging .Did i use to much oil, seen on here 3.5 ounces..? cant wait to ride it again,perfect weather in ohio deer season:
Old Nov 25, 2007 | 10:59 PM
hoytultratec's Avatar
try a search on counterbalance oil ton of topics on it...might help few different awnsers?
kelleycully
Sep 15, 2016 02:57 AM
Chocobamofo
Jul 10, 2015 07:46 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
