1996 Magnum 425 ATV
Old Nov 28, 2007 | 01:22 PM
logan800's Avatar
Default 1996 Magnum 425 ATV
Machine was running fine with no problems. It just quit and will not start. No spark. I replaced the stater and I get 1 spark when I try to start it. Please help
Logan800
Old Nov 28, 2007 | 02:13 PM
94harley's Avatar
Unplug the black wire on the reverse limiter and see if it changes.
Old Dec 4, 2007 | 02:43 PM
logan800's Avatar
Removing the black wire did not help my cause. This machine is baffeling me.
Old Dec 4, 2007 | 06:02 PM
ftwflh's Avatar
Check all the electrical conections esspecially the grounds.
If nothing is loose or corroded I would check out thet coil first then the stator
Old Dec 5, 2007 | 11:39 AM
logan800's Avatar
Took the coil in and had it tested. It is fine. Running back through connections and grounds.
Still hoping for a miricle.
Gwolf228
Feb 18, 2017 01:36 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Sep 9, 2015 06:57 AM
chewy78
Sep 8, 2015 10:37 AM
