kfx wont start
Old Dec 5, 2007 | 07:13 PM
bauman92's Avatar
Default kfx wont start
[img]i/expressions/face-icon-small-confused.gif[/img] my kfx just started to stop starting the battery is new and good,connections are good, ive got fuel, its cranks over but it just wont start. but it starts when its been warmed up? what could this be?
Old Dec 5, 2007 | 09:36 PM
kwackermann's Avatar
Check your valves..................
Old Dec 6, 2007 | 04:08 AM
hondabuster's Avatar
The intake valve has probably tightened up, and doesnt close completely. This leads to a big frop in compression, and a difficult to start motor when cold.
Old Dec 6, 2007 | 11:55 AM
Hayashi's Avatar
Since it starts when engine is warmed up but not when cold, I would also check choke/carburetion area.
Old Dec 6, 2007 | 05:02 PM
bauman92's Avatar
i had 295 size skim in and went to a 290 and it still wont start. should i go smaller?
Old Dec 6, 2007 | 05:03 PM
bauman92's Avatar
i checked the carb and cleaned it out good and the choke seems to work fine could it be my CDI?
Old Dec 6, 2007 | 07:56 PM
flipng's Avatar
i had a problem with my kfx not starting the battery went bad and had to replace the plugs then it started fine.
Old Dec 7, 2007 | 01:22 PM
When you adjust the valves, go by the clearance, which is checked with a shim. Then youll know what the proper shim will be.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
