primary spring help
Old Dec 5, 2007 | 07:48 PM
redman1's Avatar
Default primary spring help
i have a 07 800 with 27" swamplites and i want to change the factory primary spring to dalton(orange and blue).i've never done this before and was wondering how hard it will be and are any special tools needed . any help will be greatly
appreciated. thanks
Old Dec 5, 2007 | 08:06 PM
SPORTSMAN70003's Avatar
Thats the same spring I run and really like it. Basically all you do is remove the clutch cover and pull your belt off. To pull the belt off pull up on the belt and roll it off the secondary. Then take you center bolt out of the primary and then the 6 smaller bolts. Be careful while pulling the 6 bolts out as the cover will be under a little pressure from the spring. Pull your stock spring out and replace with the new spring. Then just reverse those direction. Also mark the cover on the primary and put it back on just like you took off because the primary's are a balanced unit. Also welcome to the forums.
Old Dec 6, 2007 | 01:21 PM
redman1's Avatar
thanks sportsman70003,i'llgive it a try this evening
Ridgerunner665
Sep 15, 2015 01:20 AM
WilliamBos
Sep 6, 2015 10:53 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
