03 prairie 360 ?
Old Dec 6, 2007 | 06:36 PM
flipng's Avatar
Default 03 prairie 360 ?
problem started with bike staying idled up after throttle was released. checked diaphram in carb changed gas drained carb any more ideas would be nice.
Old Dec 7, 2007 | 02:56 PM
Hayashi's Avatar
Do you mean the throttle is stuck and the engine rpm is kept up by itself? If so, check the choke cable, and plunger for binding/sticking. If OK, then check the throttle cable reel at the carb side.
Old Dec 7, 2007 | 09:12 PM
flipng's Avatar
throttle isn't stuck. plunger is fine not sticking.will check throttle cable reel.
Old Dec 8, 2007 | 10:16 PM
alwaysride's Avatar
If your saying it has problems idling. Get the valves adjusted.
Old Jan 2, 2008 | 08:05 PM
wcabadbrute's Avatar
check the tube that goes from the carb to the motor. that mite have a cut in it. mite even check the chock cable. if the chock is on at all the motor will idle up some. how high is the idle getting?
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
PrairieDog126
Sep 12, 2015 05:23 PM
coolguy420
Jul 10, 2015 01:17 AM
coolguy420
Jul 9, 2015 09:54 PM
