kfx 700
Old Dec 6, 2007 | 07:18 PM
flipng's Avatar
Default kfx 700
recently added white brothers carbon pro exhaust. jetted carb with stage 1 dyno kit.
ran fine for a little while now it's starting to sputter and pop any ideas?
Old Dec 6, 2007 | 11:26 PM
destrehanrider2008's Avatar
Default kfx 700
its probably running a little rich
what was the stock size jet?
and what size did you put in?
also did you put a full system or a silencer?
Old Dec 7, 2007 | 05:12 PM
Hayashi's Avatar
Default kfx 700
Since it ran fine in the beginning, it might not be a jetting issue which should show up as a problem immediately if the setting was incorrect. Check the air box bottom for any engine oil residue. Also, check for any air intake leak.
Old Dec 7, 2007 | 08:54 PM
flipng's Avatar
Default kfx 700
don't remember the stock size jet. put 120 in the front and 124 in the rear. it was a full exhaust.
Old Dec 7, 2007 | 09:02 PM
flipng's Avatar
Default kfx 700
the sputtering started when we went to kentucky. thought it might be an altitude thing but got worse back in va.
Old Dec 7, 2007 | 09:06 PM
flipng's Avatar
Default kfx 700
what does it mean if there is oil residue in the air box. i ask because i did have oil residue in the air box of my prairie 360.
Old Dec 8, 2007 | 05:24 PM
stillV1's Avatar
Default kfx 700
I' ve got a kfx700 and I am just learning about it but on kfx700.net, those guys talk about a 12 hole airbox mod. after they pipe and jet it. In alot of cases , all 12 holes are not open depending on jetting and altitude but I agree with the others that I would check jetting first. I do remember reading that a couple guys were having similar problems and were told to get it breathing on the front end better with the airbox mod. Good luck...let me know how it turns out!![img]i/expressions/face-icon-small-smile.gif[/img]
