400 PRAIRE DRIVE CONVERTER
Old Dec 7, 2007 | 02:59 PM
DUNNAR's Avatar
Default 400 PRAIRE DRIVE CONVERTER
I JUST BOUGHT A KAWASAKI PRAIRE 400, I THINK IT IS A 2000- AND IT RUNS GOOD BUT DOESN'T MOVE VERY WELL. I WAS WONDERING WHAT TO REBUILD OR REPLACE? DO I NEED A CLUTCH KIT OR IS THERE SOMETHING ELSE?
Old Dec 7, 2007 | 03:02 PM
Hayashi's Avatar
Your CVT belt might be slipping due to excessive wear - too much deflection. Remove the CVT cover and inspect the belt and the converter sheave surface.
Old Dec 7, 2007 | 03:29 PM
DUNNAR's Avatar
I think it might be more than that, the clutch clanks and rattles alot. I have the cover off and the belt looks fine. The front snorkle has a hole in it, so I think it got some junk in it. THANKS
Old Dec 7, 2007 | 04:21 PM
Hayashi's Avatar
If it makes such noise, then the wear buttons on the drive converter are worn out, and/or the bushing is worn out at the shaft. Remove the belt/drive converter from the crank and run the engine on the stand. If no noise, then it is the converter.
Old Dec 7, 2007 | 05:07 PM
DUNNAR's Avatar
Is that something a shade tree mech. can do, or does it take alot of experiance. Does the parts cost alot?
Old Dec 7, 2007 | 05:57 PM
Hayashi's Avatar
Besides the wrench turning skill, you would need specs for clearance selecting the correct shim size. Get a service manual if you think you would keep the quad for a while.
Old Dec 7, 2007 | 06:11 PM
DUNNAR's Avatar
Thanks for the help!
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Oct 10, 2015 10:20 AM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 15, 2015 02:45 PM
RNN
Sep 5, 2015 12:43 PM
