magnum 325
Old Dec 8, 2007 | 06:59 PM
terryb4471's Avatar
Default magnum 325
I just purchased a 2002 magnum 325. In changing the front hub oil the manual says to turn the hub to 4 oclock. The dealer where I purchased the oil had a chart that said 5 oz oil. I drained the hub oil and 5oz didn't come out. It doesn't take 5oz when turning the hub to 4 oclock. Has anybody changed the oil and how much oil di you use.
Thanks Terry
Old Dec 8, 2007 | 11:49 PM
sportsman rocks 's Avatar
Default magnum 325
Drain all oil and refill to 4 o clock. Some times all the old oil don't come out, so you mite want to flush it a couple time to get all the dirty fluid out. Hope this helps some.
Old Dec 9, 2007 | 01:05 AM
badwelder's Avatar
Default magnum 325
I flush it out with trany fluid then use hub fluid . sometimes they leak a bit or fluid breaks down so I change it often.The manual says 4o clock
Gwolf228
Feb 18, 2017 01:36 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Sep 9, 2015 06:57 AM
Dan Newberry
Aug 30, 2015 09:42 AM
