02 400EX axle bearings
Old Dec 11, 2007 | 01:51 PM
markbo_43764's Avatar
Default 02 400EX axle bearings
how do i get the bearings out of the carrier?
Old Dec 11, 2007 | 11:06 PM
HiLi_Psyclez's Avatar
If you heat the carrier w/ a propane torch, then get a big socket or something else you could use the size of the outter ring of bearing and knock it out. Ive heated them and tapped the carrier on my workbench which works good also if you dont have anything big enough to drive it out.
when you install the new ones, put the bearings in the freezer for about 45 mins, right before you take them out heat the carrier up. They should fall right in
Good luck;...
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
Honski250r
Sep 26, 2015 09:40 PM
1000gade
Sep 9, 2015 04:41 PM
Elkaholic
Sep 6, 2015 02:44 PM
