Bayou 300 Neutral Light
Old Dec 12, 2007 | 01:24 PM
SammyK's Avatar
Default Bayou 300 Neutral Light
I picked up a Bayou 300 4x4 recently. Regardless of what gear it's in, the neutral light remains on. I'm guessing that the switch controlling the light must be disconnected or broken. Does anyone here have any experience with this problem? Any insight will be greatly appreciated.
Sam
Old Dec 12, 2007 | 03:25 PM
Hayashi's Avatar
I am thinking you have a bad neutral switch. Actually it is a combo switch of Neutral and Reverse function, 2 swtiches in one assembly, which is located on the left side of engine where your left lower leg would be as you are sitting on the quad. To find the switch, just follow two wires coming from the neutral/reverse lamps, one is light green (Neutral) and the other is Red/Wht (Reverse) wire but they are in black vinyl protective tube. The switch assembly is held by two small screws (5mmx14mm) on the left side of engine. Sometimes just removing and cleaning w/ contact cleaner and reinstalling the switch fixes the problem. The swtich sometimes gets stuck in closed postion (light on always) and would not open up (light off).
Old Dec 13, 2007 | 10:28 AM
SammyK's Avatar
Thanks for your reply.
I took a quick look at the quad last night. It looks like I'll have to remove the sub-transmission just to get to the switch. I'm wondering if it's worth the effort. I may just leave it for another day.
Hondamx751
Aug 13, 2015 01:06 AM
Aug 11, 2015 11:56 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
JoAnnS
Jul 23, 2015 02:18 PM
