prairie 360 snorkle, bigger tires
Old Dec 14, 2007 | 11:07 PM
hummer93516's Avatar
Default prairie 360 snorkle, bigger tires
i have a 05 prairie 360 and i wanted to get 28in tires on it. would it lose power from bigger tires, if so how much, and anyone know where to get an snorkle kit for it?
Old Dec 17, 2007 | 12:23 PM
Hayashi's Avatar
Bigger tires and snorkel sound very tempting on quads but they do have side effects that may hurt your quad in a long term.
Bigger tires - excessive wear and tear on drivetrain & CVT including the belt.
Snorkel - you would be in deeper water than w/o snorkel and all elec connectors and unsealed bearings such as ones on swing arm will bite the dust much sooner.
Just my 2 cents.
Old Dec 17, 2007 | 02:01 PM
quadzilla420's Avatar
I thought about a snorkel kit too. My thought is to make plenty of trips to "LOWES" in the plumbing dept. because I've seen kits on the i-net upwards of $200-$300. Just piece a kit together and remember that you'll need an extra large opening 2-3 pipes at the opening. Or say, for every inch in length, you'll need an additional inch or inch and a half of opening at the end. The ones I've seen on the i-net have 3-4 2" pvc leading to the breather. But like Hayashi said, you'll need to seal everything up, which is alot of work. As for tires, I've got 12 inch wide tires (w/ stock height) on my quad w/stock wheels. I didn't put taller tires and/or bigger wheels on mine because I didn't want to lose top end and I don't plan on racing the quad in an 1/8 or 1/4 mile. All I did was go from 10" wide tires in the rear to 12" wide and kept the front stock because of the steering. Wider tires in front means more muscle to turn them. Plus I added 2.5" wheel spacers all around which gives my quad a wider foot print, hence; making the quad a little lighter on ground pressure and more stable on eneven terrain, hillsides etc. With the tires, just think of a drag car. Taller tires gives you a faster takeoff but lowers top speed VS. smaller tires gives you more top speed but lowers takeoff.
Old Dec 17, 2007 | 02:15 PM
where did you get your spacers from?
Old Dec 17, 2007 | 09:29 PM
xpatv.com
They were supposed to be a custom-fit job. But
I had to drill-out 2 holes on the front wheels and all 4 on the rear wheels. It was well worth it. Since my wheels are aluminum it about 5min. or so to drill them out. Once I got half way through each hole, I took a smoke break before I finished the hole allowing time for the wheel to cool down.
Old Dec 19, 2007 | 11:44 AM
alwaysride's Avatar
how about, find some good long trails and stick with stock size tires and enjoy trail riding because mudding sucks. haha just messin
Old Dec 19, 2007 | 02:02 PM
Hell, trail riding isn't have the fun. If you can't get even a little excited when you sit on your quad, There's no since even riding the damn thing [img]i/expressions/face-icon-small-smile.gif[/img] Wheter it's trail riding, rock'n, mudd'n, saind'n or work'n, none of it sucks [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 19, 2007 | 03:05 PM
alwaysride's Avatar
haha, tru dat
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
black_thunder
Sep 7, 2015 01:24 AM
Logan Collins
Sep 5, 2015 08:03 PM
