sportsman clutch removal
Old Dec 15, 2007 | 05:11 PM
79hugger's Avatar
Default sportsman clutch removal
How can I remove the clutch spider from a Sportsman,I have the outer part off,it looks like it is screwed on?
Old Dec 15, 2007 | 05:32 PM
MOUNTAINEERRIDER's Avatar
You will need a special tool..the spider screws off ..polaris part nu#2870341.. I got mine from EPI
Old Dec 15, 2007 | 07:38 PM
79hugger's Avatar
Hi, great!! Found one on Ebay. Does the spider come off counterclockwise and how do I keep the engine from turning using the tool, impact wrench? Thanks
Old Dec 15, 2007 | 07:56 PM
harleypap's Avatar
http://video.yahoo.com/video/play?vid=1356575 if you go watch this video it will show you what to do
Old Dec 15, 2007 | 08:33 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you dont take apart your clucth on the bike. it had to be off so it can be held in place. that is a nice little video for sure.
Old Dec 15, 2007 | 08:46 PM
harleypap's Avatar
you can use a 11 mm deepwell socket so you can use a shorter fine thread bolt. to remove the clucth.
Old Dec 15, 2007 | 08:59 PM
KING4X4's Avatar
how about just to change the wieghts?
Old Dec 15, 2007 | 09:05 PM
harleypap's Avatar
you do not have to take the clucth off to do them.
Old Dec 15, 2007 | 10:34 PM
79hugger's Avatar
Actually the spider is cracked and it knocks bad so it has to be changed. I have a identical atv for parts.The video was great,so actually I need a puller to make the swap
Old Dec 15, 2007 | 11:10 PM
harleypap's Avatar
yes you do. but make your own. i think it is fine 5 /8
