Which Honda atc do i have
Old Dec 18, 2007 | 12:00 AM
revenge143's Avatar
Default Which Honda atc do i have
Hello
i have acquired a honda atc. I was told its a 200cc. I have no clue what year or model it is. Its all red, all the stickers and decals have been taken off. Its a pull start only, with a decompression cable hooked up that automatically engauges when pulling the pull starter. The left side of the engine has a small metal cover on the side of the cylinder that says CDI on it. It is a chain drive, not shaft. It seems to be semi automatic.... no clutch, just a foot shifter. Its got 22x11x8 tires on it. Its got a slide switch for the ignition, and a slide switch for the lights. Its also got a rack on the back. Im missing the front fender, so i am not sure if it was supposted to have a front rack too.
I will have pics posted soon....
hopefully someone here can help me...
Old Dec 18, 2007 | 08:21 PM
joshjines's Avatar
its probaly a 1982 or a 1984 atc honda 200s
Old Dec 18, 2007 | 10:43 PM
Gimpster's Avatar
On the base of the cylinder the cc's should be moulded (readable) into the cylinder
----- Gimpster -----
Old Dec 18, 2007 | 11:39 PM
HondaMechanic's Avatar
Does it have front suspension..?
Old Dec 19, 2007 | 02:25 AM
KNOWSALOT's Avatar
The Facility
Only the "S" models came with 8" wheels so if it's a 200 and nothing has been changed around over the years, it's an 84-86 200S.
Old Dec 19, 2007 | 07:17 AM
The ATC200S has front suspension ..The ATC185S has solid front forks , both bikes have 8" rims ..
Old Dec 19, 2007 | 08:02 AM
Here is the serial number locations and the engine year numbers for the 200S .. The engine serial number is beside the gearshifter ..
1984 .. TB05E-2300001
1985 .. TB05E-2500004
1986 .. TE05E-2537514
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
