HELP! 1985 Yamaha Moto4 YFM80N sparks once, won't fire!
Old Dec 18, 2007 | 01:37 PM
yfm80moto4's Avatar
Default HELP! 1985 Yamaha Moto4 YFM80N sparks once, won't fire!
Need your help on an issue I'm having with my 1985 Yamaha Moto 4 YFM80N. It had sat in my garage for about 10 years and was running like a champ when it was put up. 3 years ago I had pulled it out, cleaned it up, rebuilt the carb, changed all the fluids, put a new battery and new tires on it, and had it running again. I put it away yet again, and am now trying to get it going again to sell it to a friend of mine. It's got a brand-new battery in it, since I didn't store the other one properly when I put it up 3 years ago.
Here's what I know so far:
- the "neutral" light comes on bright
- the engine turns over at normal speed when the electric start is used
- definitely getting fuel
- When I ground the spark plug to the chassis and turn the engine over with the starter, it'll spark once right after the engine starts turning over then not spark again.
- The single spark I am getting is strong (white/blue).
- I'm seeing voltage fluctuation from the pulser coil when I spin the starter and check the voltage at its terminals
- I'm not sure how the check the CDI unit (no manual), but when I hook the voltmeter up to chassis ground and the orange ignition coil lead and spin the starter, I see some occasional fluctuation but not as much as I would imagine it should be putting out.
I initially thought it may be the coil, since I'm getting output from the pulser and getting one single spark. Then I started thinking it was the CDI unit not sending voltage to the igntion coil.
I've got a new coil on its way, and am hesitant to purchase a CDI unit since they're $140. Anyone have any ideas about anything else I should investigate before I spend my cash? I need to get this thing up and running before Christmas so my friend can give it to his kid.
Appreciate the help!
Old Dec 19, 2007 | 11:35 AM
yfm80moto4's Avatar
Anyone have any thoughts? I'd appreciate any help I can get!
Old Dec 22, 2007 | 02:40 PM
yfm80moto4's Avatar
Just as a follow-up, I was able to finally solve the problem with my moto4. The CDI box was shot. Swapped a new box onto it, and the plug fired repeatedly and strong. Starts up and runs like a champ now.
Just wanted to close the loop in case someone else had a similar problem.
Old Dec 22, 2007 | 03:42 PM
ctateusa1's Avatar
glad to hear you got it fixed.
Ean
Dec 19, 2022 08:48 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
Jul 7, 2015 11:00 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
