Help with starting problem 200cc loncin
Old Dec 18, 2007 | 07:52 PM
bestoffroad's Avatar
Default Help with starting problem 200cc loncin
Have a zmc 200r was running great then all of a sudden it died and it did strart again but not very well. i thpught maybe it was low on gas so i drove it to the driveway and as soon as i let off the throttle it dies again and now its a no start. i have some experience with these things and have checked for fuel and spark both are good. I even changed out the carb but still nothing. Anyone have any ideas??? I have checked all the electrical connections cant to seem to find anything. I have had these problems before but its almost always a wiring or kill switch issue. But i have spark it seems. HELP
Old Dec 18, 2007 | 11:47 PM
SilveradoSS's Avatar
I would change the spark plug to start with to see if that solves your problem. I have had plugs that would spark, but the spark was too weak to light off the engine. It would be a cheap test before moving on to replacing bigger and more expensive parts. Something else that is common among the Chinese quads is the gas tank vent in the gas cap gets blocked and the running engine sucks a vacuum in the fuel tank causing the engine to eventually starve for fuel. If you have an in-line fuel filter, it may also be blocked.
The vent problem usually presents itself as you're riding the quad around for awhile and all of a sudden, the quad bogs out and dies. When this happens, immediately remove the gas cap and listen for air sucking back into the tank. After removing and replacing the cap, try to restart the quad. If it restarts and you are able to ride around for awhile before it bogs out again, then you can reasonably suspect that the vent is not working properly.
Old Dec 19, 2007 | 03:29 AM
Jessie_atvruns's Avatar
No problems on Gas or Spark. How's the Compression? I would turn the crank shaft by hand to check if the valves work properly to provide sufficient compression. Because I had have a bunt and melt ex-valve problem in this summer. My bike showed a quite similar phenomenon at that time. Text
Old Dec 19, 2007 | 11:37 AM
hardlydangerous's Avatar
I agree check the compression.
check the petcock for fuel flow, also make sure the carb is getting fuel by loosening the drain bolt on the float bowl.
The only other thing i can think of off the top of my head is a timing issue either cam timing or ignition timing.
Old Jan 27, 2008 | 06:21 PM
jmiller67's Avatar
I have the same unit and problem. As I followed the plug wire back to the Coil It broke in my hand. It had a crack from start and no dead
Old Mar 2, 2008 | 05:11 AM
driver0tolerance's Avatar
I have one also where can i buy parts for one? Im needing a chain.
Old Mar 2, 2008 | 08:23 PM
jmiller67's Avatar
Email these guys they are great
Parker Findlay (pfindlay@zmccanada.com)
FWhitt
Jun 13, 2015 02:22 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
