HELP! 400 Prairie missing at high RPM.
Old Dec 21, 2007 | 05:44 PM
DWJ's Avatar
DWJ
Default HELP! 400 Prairie missing at high RPM.
I have a 400 Prairie 4x4 that will not run at higher RPM's. Sometimes it will run OK for just a few minutes when you first start it in the morning. Idles fine but will not even get to 1/4 throttle before it starts missing and missing badly. Sounds like it will not take gas but I replaced the carb and it does the same thing. Pickup coil tested OK with ohm meter. Switched CDI box and the same thing. This is driving me nuts!!! Any suggestions?
Old Dec 21, 2007 | 07:25 PM
kwackermann's Avatar
Hmm- sounds similar to what I experienced when I tried to cover up the intake on my uncorked Mojave. Would start and run OK- but wouldn't wind out, opened it back up and was OK. Have ya checked the air filter. Also check the battery, these P400's are known to act this way with a questionable battery..........
Old Dec 22, 2007 | 08:48 AM
DWJ's Avatar
DWJ
<div class="FTQUOTE"><begin quote>Originally posted by: kwackermann
Hmm- sounds similar to what I experienced when I tried to cover up the intake on my uncorked Mojave. Would start and run OK- but wouldn't wind out, opened it back up and was OK. Have ya checked the air filter. Also check the battery, these P400's are known to act this way with a questionable battery..........</end quote></div>
Checked all that you mentioned. Also tried a new main coil and still the same thing. This a stock unit. No mods ever done to it.
Old Dec 22, 2007 | 11:46 AM
Hmm- OK, I'll keep tryin' to find something. Noi doubt you've checked the spark plug. NYROC is a good source, too........
Old Dec 22, 2007 | 11:53 AM
DWJ's Avatar
DWJ
Problem solved. The breather tube that runs up to the front was obstructed.
Old Dec 22, 2007 | 03:46 PM
Hallelujia.............
2quiker
Mar 22, 2022 08:36 PM
Steeldon
Sep 9, 2015 09:38 AM
black_thunder
Sep 6, 2015 04:41 PM
Elkaholic
Sep 6, 2015 02:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
