2005 bruin
Old Dec 27, 2007 | 06:36 PM
newf30's Avatar
Default 2005 bruin
my bike smokes when i start it after it sits for awhile??????? the valve seals were replaced and it stalls out when i go in water some times????? please help
Old Dec 28, 2007 | 02:41 PM
2FAST4URASS's Avatar
Default 2005 bruin
Well normaly when it smokes when you start it up and doesnt keep on smoking after about minute or so it is the valve seals and if it keeps on smoking time for a rebuild I have a 2005 raptor 350 and after it sits and I start it up using the choke it will smoke pretty good but only if I use the choke but it smells of oil and gas burning But im not worried about it and as long as your Bruin dosnt smoke all the time I wouldnt worry about it just keep tab of your OIL. And as for it stalling it maybe wiring pull apart all the connections one by one and put some electrical grease in em real good and put em back togather watter proof grease though and get some silcone spray and spray down your plug wire real good to make sure it is watter tight try that and if it doesnt work make sure all your carb connestins are tight ..But just for thought I have a 2005 BRUIN too and mine has always stalled if i splashed threw watter fast but it would clear up after like 30 seconds to a min..
Old Dec 28, 2007 | 10:56 PM
newf30's Avatar
Default 2005 bruin
thanks for the info
salixair
Nov 3, 2015 08:25 AM
01ssls1
Sep 22, 2015 06:50 AM
Lou Domenech
Sep 11, 2015 06:35 PM
Brandon400
Sep 5, 2015 08:44 PM
