2004 wolverine ome way bearing
Old Dec 29, 2007 | 09:37 AM
Shotgunshrimp's Avatar
Default 2004 wolverine ome way bearing
does anyne know is the 1 way bearing in a wolverine the same as a raptor.. if so should i worry about buying the ladesigns one way?? or just go with stock and deal with them dieng.. TIA
Old Dec 29, 2007 | 10:53 AM
ctateusa1's Avatar
go to yamaha-motor.com and find the parts diagrams and you can compare the numbers of the two bearings.
Old Dec 29, 2007 | 03:20 PM
the part numbers are very close but not the same but each model get diffrent part numbers no matter what... i dunno guess i buy stock and hope it doesnt blow it up
Old Dec 29, 2007 | 03:29 PM
ctateusa1's Avatar
actually a lot of the part numbers for different models are the same for things. usually if it is a different number there is some detail that will be different might be a different outside or inside diameter or just a different number of rollers inside it, you wont know until you buy one and compare the two.
Being a honda technician there are a lot of seals that are the same size and will interchange but have a little different look to them and therefore they recieve a different part #.
exmotocrosser
Sep 13, 2019 06:12 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
jbrewster94
Sep 23, 2015 04:16 PM
