Jetting
Old Jan 11, 2001 | 10:26 AM
RedDog400ex's Avatar
I think my 400ex is running a little rich it is puffing black smoke. Which jet do I change, the slow jet or the main jet, or both. Thanks for the help.
Old Jan 11, 2001 | 06:31 PM
Would it help if I just put a few more plates in my exhaust to lean it up?
Old Jan 11, 2001 | 08:55 PM
400exalltheway's Avatar
i'm not to firmilar w/ supertrap pipes so i'm not sure about the plates. what size jet is in it now(main jet) and what performance mods do you have other than that if any?
Old Jan 11, 2001 | 11:37 PM
I think its a 152 main jet I have a K&N power kit and the supertrapp with 10 plates
Old Jan 12, 2001 | 04:16 PM
EXtreme-'s Avatar
Adding more plates (discs) to the tail will lean it some...the reason for the discs are to "fine tune" your tail to the engines liking. Check your plug to see if its all black and nasty, if so, install the stock 148 main. A simple test would be to remove all the discs and run it to see if it's still over-rich....before changing the main. Not to sound stupid, but make sure the air cleaner is in top shape and not all stuffed up with dirt.
Old Jan 12, 2001 | 11:45 PM
Thanks for the info, I'll give that a try, My spark plug was all black and nasty. I just cleaned the air filter about a week ago.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
