400EX'ers (HELP!!!) I NEED YOU
Old Jan 11, 2001 | 01:13 PM
RobRider's Avatar
STOP!! PLEASE REPLY IF YOU HAVE ANY IDEAS. DON'T LEAVE A FELLOW RIDER HANGING. THANKS
I have a 2000 400ex and have done nothing to it at all as far as mods. It has serious problems with backfiring and sputtering. It will run great until the engine gets somewhat warm, then it backfires and sputters and stalls. From then on it won't stay running at all. I'm not to knowledgeable about fixing a problem like this, so if you do know how, please take the time to explain. THANKS ALOT.
Old Jan 11, 2001 | 03:27 PM
redrocker's Avatar
Put a new plug in first than spray starting fluid around the intake if it revs up you have an intake leak hope that helps
Old Jan 11, 2001 | 04:30 PM
joelpolaris's Avatar
sound like it is sucking a valve. A friend of mine had the same problem on a Wolverine. We removed the valve access covers and noticed that the intake valve was not closing. It tunred out that the oil pump had failed and the cam was not getting any oil. this caused the rocker arm on the intake side to seeze. Check the timing first.
Old Jan 12, 2001 | 04:26 PM
sAyIt_fmf's Avatar
Have you had the valves adjusted lately?
If the plug and filter check out...I would look into the valves and or timing
Old Apr 16, 2004 | 05:45 PM
400excrazy's Avatar
Default 400EX'ers (HELP!!!) I NEED YOU
get a new plug!!!!!!!!
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
