03 yamaha banshee
Old Jan 1, 2008 | 01:42 AM
chaveno's Avatar
Default 03 yamaha banshee
i have a banshee but parket it one day try to started the neex day and it dint start. check the spark plug and dont have spark dont know what to check and how to check it can any one help
Old Jan 1, 2008 | 10:21 AM
Scooter86's Avatar
Knows Old ATV Questions!
First thing, replace the plugs and check again. Still no spark then you will need to check the ground. After cleaning that up if it still won't spark you will probably have to check the wiring harness for problem areas.
Old Jan 1, 2008 | 10:53 PM
wcabadbrute's Avatar
check the stator and the coil. there should be two wires on the coil. one is the ground and one is the signal wire. check the ground system first.
2quiker
Mar 22, 2022 08:36 PM
Sep 17, 2015 03:06 AM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
