05 Brute Force 750 fan
Old Jan 1, 2008 | 10:21 AM
JMF750i's Avatar
Default 05 Brute Force 750 fan
My BF started over heating and I found out that the fan wasnt coming on, so I replaced the fan switch on the radiator adn that didnt fix it. Ive look on the oem parts finders and havent found if there is a fan relay that could be bad. Is there a fan relay? Otherwise I was goin to try and replace the fan breaker. Could that be my problem? Any info will be a great help. Otherwise its off to the stealership for me.
Old Jan 1, 2008 | 12:25 PM
JMF750i's Avatar
Am I at least on the right track??
Old Jan 1, 2008 | 02:01 PM
Force's Avatar
I have a 04 V FORCE and fan was shot-froze up.Put new one in 2 years ago and no problems since.Easy install but fan was'nt cheap.
Old Jan 1, 2008 | 02:08 PM
wcabadbrute's Avatar
there r two things u can check. ther is a tempature switch that operats the fan were the termastat housing is. and also there is a relay underneath the seat. it has on wire on each side. it looks like a fuse. if it is bad then u can replace it with a 20 amp fuse. ther is also a fuse in ur fuse box under the seat. make sure the fan moves freely
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
ylomnstr
Sep 10, 2015 06:45 AM
ylomnstr
Sep 4, 2015 05:02 PM
