kfx 400 mods
Old Jan 2, 2008 | 02:41 AM
gumby58's Avatar
Default kfx 400 mods
I have a 2004 kfx 400 and i want to make it faster with a cheap bill..any suggestions
Old Jan 2, 2008 | 09:58 AM
AIRMOBILE101's Avatar
Is this thing completely stock now?
Old Jan 2, 2008 | 10:19 AM
scootergptx's Avatar
Supersock
Hired Gun!
Assuming it is still stock, a few aftermarket parts will be a start. Also depends on what you call cheap.
K&N or Uni filter, slip on pipe, or full exhaust (rejettig the carb of course), performance CDI, changing the front sprocket would be a good start.
If you're really on a budget, just do the air filter and get a bigger exhaust tip for the stock pipe, and change the front sprocket and change the jets on the carb. Don't buy the whole jet kit, just get them from a dealer. Won't make it light speed fast, but you'll notice a difference from what it was. Should be able to get all those parts new on ebay for under 100 bucks.
Old Jan 2, 2008 | 11:06 PM
gumby58's Avatar
I HAVE ALREADY GOT A FULL ALBA PIP AND JET KIT WITH A AFTERMARKET CDI BOX. ALSO HAVE K&N AIR FILTER. WHAT SIZE OF FRONT SPROCKET YOU RECOMEND? ANYTHING ELSE
Old Jan 3, 2008 | 01:07 AM
I would say Hotcam time!!!!!!!! But, you said a cheap bill. So, you could drop down 1 front tooth sprocket and render your first gear totally worthless, or add 1 tooth for top end. Its pretty much depends on your riding style. I run a 38 REAR W/ 14T FRONT. I only weigh 130 lbs. So, I can sacrafice some torque for top end.
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
