ARCTIC CAT 500 HELP
Old Jan 3, 2008 | 07:32 PM
ADAMSQUAD's Avatar
Default ARCTIC CAT 500 HELP
i had my front bumper put on a while back, and now i seen i was missing one of the main bolts that hold on the bumper at the bottom on the frame, so i got a new bolt from cat exactly the same and i find out the hole is stripped. what can i do?PLEASE HELP
Old Jan 3, 2008 | 11:21 PM
BYBob's Avatar
You could go to the hardware store and buy a tap set and rethreat the nut, or you can buy a longer bolt and nut and a lock washer and put the bolt thru and screw the nut on with the lock washer and that should keep it..Good luck.
Old Jan 4, 2008 | 12:47 AM
ADAMSQUAD's Avatar
how does a tap set work and also would i need a bigger size bolt. and also i dont think i could use a longer bolt and nut and locking washer because it goes directly into the bar of the frame and there would be no way of getting the nut in there
Customer Service #1
May 15, 2020 08:46 AM
shimanok2
Jan 29, 2016 07:37 PM
brad patnoe
Sep 23, 2015 06:44 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
Sep 1, 2015 01:45 AM
