new headlight bulbs
Old Jan 9, 2008 | 09:40 PM
linkup's Avatar
Default new headlight bulbs
I have a 2005 ac 500 LE the low beam has blown..
Has anyone found aftermarket bulbs that will fit..
Old Jan 12, 2008 | 08:56 PM
Junkman673's Avatar
I've looked everywhere foe the. I had to go to the dealer and pay 13.00 a piece.
Old Jan 12, 2008 | 10:32 PM
badmoose's Avatar
I had a 05 650 the bulbs in it were regular bulbs that were at any auto parts store. Might be the same bulbs as what you have not sure. take the bulb out an read the numbers off the bulb and call around to see if there are any besides what the dealer has.
Old Jan 14, 2008 | 10:38 AM
ewalden's Avatar
I found the bulbs at Walmart I'll have to fine the number, do a search on this page, someone told me where to get them. I hope this helps !
Ed
Old Jan 14, 2008 | 10:43 AM
ewalden's Avatar
This worked on my 04-650. Walmart $7.00 each
Sylvania SliverStars or regular quartz-halogen 893's I believe both are brighter then stock too.
Old Jan 14, 2008 | 06:08 PM
doggoneit's Avatar
<div class="FTQUOTE"><begin quote>This worked on my 04-650. Walmart $7.00 each
Sylvania SliverStars or regular quartz-halogen 893's I believe both are brighter then stock too.</end quote></div>
Great advice, Thanks! I went by Advance Auto Parts and picked up a 893 for $7.00 just like you said and it's brighter than the stock bulbs.
Old Jan 15, 2008 | 12:20 AM
frndinalowplace's Avatar
silverstars ftw!
Old Jan 15, 2008 | 07:36 AM
Williebee's Avatar
Ed how does the blub's you're talking about work on your AC ?
Do they get hot enough to melt the plastic len's on your quad ?
Are does your Cat have the plasic len's ?
I hate the stock light's that came on 06' AC 400 i can't see to drive at night with the stock one's , but i heard someone say that a regular bulb for a car would melt the plastic len's ; does it ?
My old Honda with just the one light mounted on the handle bar's was bighter than both light's on my Cat !
I bought a set of those driving light's but i haven't tried them yet i didn't known if they would pull to much juice than the charging system could handle , let me know how they turn out !........
Williebee's Avatar
Well since i got this double post because i got a flagged tag , with error code ; i'll just take the spot to tell you all thank's for the info Ed and you too Dan i appeicate the info guys !........
Old Jan 15, 2008 | 07:46 AM
Williebee's Avatar
Thank's for the info Ed , and i should've ask you if they were brighter than the stock bulb's ; i know aboult using the CRC Di - Electric Grease everyone use to keep the light socket's and bulb from burning out !
I had troulbe with the light's on a Suzuki KQ of my cousin's that kept blowing them at 10 buck's a pop , since then i've used it on all the electricial system ; and saved a ton of money since then and thank's again for the reply !....
